Thinking of getting the FN01RC wheels in 17x10JJ but wondering if I should get the +12 or +35 offset. My rear fenders are rolled slightly and my car is pretty low with Toyo R888 tires. Anyone running a similar setup or have any advice on whether it will rub?
you will need coilovers. I have the 17 x 9s and 255/40 tires and i am just barely clearing the strut
if you will get +35, you will probably have to put a 20mm spacer, to push the wheel outside. But then you may have to get wider fenders to clear the outside of the wheels, or run crazy camber upfront
