Adjusting Rear Camber
Old Nov 30, 2007 | 01:03 PM
PurgeIt's Avatar
For those of you running coilovers, how do / did you adjust camber? Every coilover on the market has a pillowball plate up top w/ no accomodation for camber adjustment. Do / did you use an adjustable lower arm like those from NAMS?
Old Nov 30, 2007 | 04:20 PM
klabe's Avatar
Just with the two original excenters you can adjust toe and camber with.
/klas
Old Nov 30, 2007 | 04:25 PM
nick735's Avatar
If you need more camber than stock, you can always go with these
The most camber ive been able to get while still maintaining zero toe was around 1.3 degrees...
