how is it to get service for Ohlin's coilover?
Old Dec 21, 2007 | 12:22 PM
vroomevo's Avatar
hello, if i get brand new ohlin coilover, how is it to get service in futre if these coilovers go bad???
seems like KW variant has really good custom service and it's easy to get service if somethings goes wrong...
any input would be helpful. thanks.
Old Dec 21, 2007 | 12:36 PM
GTWORX.com's Avatar
Ohlins is in North Carolina. Very easy to deal with. Pretty quick turn around time and they can revalve/rebuild to your specs. Or just tell them the spring rates you're running and they can valve your coilovers accordingly.
We work with them all the time. Good people.
- Andrew
Old Dec 21, 2007 | 12:41 PM
vroomevo's Avatar
Thanks for the quick reply andrew.
still haven't decided btwn KW variant3 and Ohlins DFV/stage 3 coilover.
daily driver but don't mind ride comfort, occasional track, 1-2/year.
hmm...
since they look about the same, i am now looking into customer service. ^^
Old Dec 21, 2007 | 12:43 PM
tvbf1's Avatar
Where do you track at?
Old Dec 21, 2007 | 12:50 PM
vroomevo's Avatar
in NM, closer to Tucson, AZ.
Old Dec 21, 2007 | 12:56 PM
DaWorstPlaya's Avatar
There are several places that revalve Ohlins and have quick turn around times, Ohlins USA as GTWorx mentioned is one of them. Performance shop in CA supposedly has quick turn around times. Works also revalves Ohlins .... For a full list check this:
http://www.ohlinsusa.com/ÖhlinsUSA/S...6/Default.aspx
nick735's Avatar
hmm...
I used to have kw v3's but i switch to ohlins dfv, if that tells you anything.
Old Dec 21, 2007 | 01:00 PM
vroomevo's Avatar
hmm...
thanks alot guys for the replies...
so, Andrew from GT works(if you still follow), how much shipped for ohlin DFV stage 3 coilover to 85745? thanks.
Old Dec 21, 2007 | 01:08 PM
GTWORX.com's Avatar
Both are awesome, but I think in your case Ohlins are the easier solution. Less headache, everything comes as a complete package. Valving is a little better with the Ohlins, just a bit. Service with both is great really.
Sending you a PM now.
- Andrew
butters149
Jan 19, 2015 09:07 AM
troy@WORKS
Evo 'For Sale' Suspension / Brakes / Handling
Aug 11, 2009 01:24 PM
Bill@WORKS
Apr 9, 2009 08:58 PM
pao
Oct 9, 2006 07:20 AM
S1monLM
Mar 21, 2006 08:29 AM
