coilovers
Old Dec 23, 2007 | 01:55 PM
brokenRS's Avatar
coilovers
what are some good streetable one for its price? been searching around, people mainly say what they have on theirs but any pointers?
Old Dec 23, 2007 | 01:58 PM
bluebyu36's Avatar
tanabe sustec pro 2 best thing i ever bought for the evo....
Old Dec 23, 2007 | 04:13 PM
brokenRS's Avatar
bump for more
Old Dec 24, 2007 | 12:39 AM
chrismnj's Avatar
Originally Posted by chrismnj
A good coilover setup has several advantages over lowering springs that fit in the stock struts.
The first, and really most important feature is adjustability. You can set the height of the car, within a range, without removing the suspension. Second, In a properly designed coilover system, the shock absorbers are designed and valved to operate optimally at whatever height setting the driver chooses. When a simple lowering spring is installed in the factory strut, it may cause the factory shock absorber to operate improperly, sometimes causing the suspension to smash the bump stops on rough roads. That can be bad for both your handling and your wallet. Third, because of the narrower wind of most coilover springs, the camber of the wheels can be adjusted, either using camber plates or hogging the mounting holes in the strut mounts (the budget racing solution).
Originally Posted by GTWORX.com
1. Ultimate set-up: Ohlins fixed perch adjustable dampers with either Swift or our own GTWorx springs
2. Awesome: Bilstein HD dampers (or EVO MR Bilsteins) with Swift or GTWorx springs
3. Good: stock EVO dampers with Swift or GTWorx springs.
Both the Swifts and our GTWorx springs are great. The Swifts lower the car a little more then ours, but are a little softer. Pick which ride height you like better.
You can add a rear swaybar and some Whiteline bushings if you like, but for just a DD, you don't really need to.
- Andrew
just my opinion....
does it help?
Old Dec 24, 2007 | 10:30 AM
madmax199's Avatar
Megan racing is the best bang for the buck for street/ and some track.
Old Dec 26, 2007 | 07:36 AM
Jazzie604's Avatar
is this referring to their street set up or track set?
Old Dec 26, 2007 | 10:34 AM
Turboed Evo's Avatar
I'd agree.
Old Dec 26, 2007 | 11:06 AM
DaWorstPlaya's Avatar
If you are looking for coilovers with the best level of comfort for the street while giving you the ability to control height, Bilstein PSS-9s. Good quality lowering springs are also another cheap alternative.
Old Dec 26, 2007 | 01:44 PM
matt6g72's Avatar
What is the best bang for the buck for around $1000 as far as coilovers for casual tracking?
Old Dec 26, 2007 | 01:51 PM
Turbolover's Avatar
Megan street or track.
GTWORX.com's Avatar
Make sure some of that 1000 is set aside for brakes.....
You can track the car on stock suspension. Not really on stock brakes.
- Andrew
Old Dec 26, 2007 | 01:53 PM
matt6g72's Avatar
Ok. So I know nothing about good brakes, so I will do more searching. Thanks for the tip!
Old Dec 26, 2007 | 02:05 PM
GTWORX.com's Avatar
Good pads and fluid is all you really need. SS lines help too.
For pads, Ferodo, Pagid, and PFC are all great. Let me know if you need any help.
- Andrew
Old Dec 26, 2007 | 05:14 PM
Noob4life's Avatar
Notice how nobody ever says their coilovers are not good, and not streetable? There's a couple of reasons for that.
So ask for a good and streetable coilover, and you'll get 10 different answers with each person swearing up and down that their choices are the best for you. How do they know that? Better yet, how do YOU know that? You don't, and you sure as heck won't find out by asking vague questions like this.
My pointer: Tell people what you plan on doing with the car, what your budget is, what you've used in the past for comparison and what is more important - ride comfort or actual performance.
Old Dec 27, 2007 | 11:03 AM
good streetable
Any time good and streetable are used with no mention of track use, its natural to assume comfort is the main priority. Ofcourse none of us are psychics ... I've been lucky enough to try out a few different coilovers to notice the differences, eg: Bilsteins, KW V3, Ohlins DFVs, stock EVO and stock MRs.
