rotor
Old Dec 29, 2007 | 01:48 PM
aceinthesky2002's Avatar
rotor
is my rotor messed up it has a small line in it from the brake pad can i just change out my pad or do i need to replace rotor also.
Old Dec 29, 2007 | 02:03 PM
nuggy00's Avatar
What's the depth of the scratch and what caused it.
I would pull the pad and investigate. If the scratch is superficial, i'd leave as is, if it is deeper, you'll have to evaluate how deep.
The big question i have is how did it happen? Is there something embedded in the pad?
Old Dec 29, 2007 | 02:14 PM
chu's Avatar
chu
It looks like getting the rotors cut would be an easy fix. However, you will need new pads if you get the rotors cut. Doesn't look problematic though.
Old Dec 29, 2007 | 02:28 PM
Robevo RS's Avatar
no worry, probably stone or something stuck it there . you will be fine.
Old Dec 29, 2007 | 03:59 PM
krazirob's Avatar
yeah man no biggie......turn the rotors and get a set of new pads............too easy bro......laters
Old Dec 29, 2007 | 04:14 PM
mini_evo's Avatar
if the pads and rotors are worn..... let them ride til it is time to replace! my S-10 had a 3/8 deep gouge in the right front rotor for almost 6 months and i didnt have problems stopping while pulling a trailor.
Old Dec 30, 2007 | 07:11 AM
Zeus's Avatar
Pull the pad and see if anything is still caught in it... otherwise you are fine.
BTW DO NOT "cut" or have your rotors "turned". See links:
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
https://www.evolutionm.net/forums/sh...ad.php?t=81487
It's NOT just an opinion...
