Can this tire be plugged? (Pics)
Old Feb 9, 2008 | 02:17 PM
Exciting News's Avatar
Exclamation Can this tire be plugged? (Pics)
Well, pulled about a 2 inch nail from my winter tire. I have a plug kit but am unsure whether the hole is too close to the sidewall to be plugged. I tried to get as much angle as I could in the pics to give perspective.
Any knowledgeable people able to lend some advice?
Attached Thumbnails Can this tire be plugged? (Pics)-tire2.jpg   Can this tire be plugged? (Pics)-tire1.jpg   Can this tire be plugged? (Pics)-tire3.jpg
Old Feb 9, 2008 | 02:30 PM
MasterNater's Avatar
Can it be plugged? Yes. Would it be safe to drive on afterwards? I wouldn't risk it. That's too close to the sidewall, IMO. I realize the dilemma you're in. Save some money and just patch it, or have to buy at least one brand new tire. Or if it's not leaking that fast, you could try to put up with having to fill it up every now and then. Either way you look at it, it's a crappy situation.
Old Feb 9, 2008 | 02:34 PM
Sosa33's Avatar
yeah u can for about 500 or 1000 miles...
Old Feb 9, 2008 | 02:44 PM
kurtzevo8's Avatar
I've had to get a couple tires plugged now, and any good tire shop will tell you that it's unsafe/pointless to plug a tire within one inch of the sidewall... too much flex. Most won't even do it.
Old Feb 9, 2008 | 02:59 PM
t51splbb's Avatar
You never want to use a plug and risk the chance of it coming out at high speed, a patch is a better alternative. If the that was my tire in the picture I would just buy another one even if it could be repaired.
Old Feb 9, 2008 | 03:07 PM
quick silver 8's Avatar
if you got the money just buy a new tire just to be safe
Old Feb 9, 2008 | 03:08 PM
I may try the patch. I'll take it off tomorrow and see what the tire shop thinks.
I thought you couldn't replace just 1 tire on an Evo (or most awd vehicles for that matter)? These have about 8k on them.
Old Feb 9, 2008 | 09:46 PM
CaliMR's Avatar
If you patch it, get a semi truck patch. They are bigger than the standard ones. The place out here that does them, they will patch even in the middle of the sidewall. However, I would not risk it on my evo, but we have stuck them on the trucks at work and never had a problem.
Old Feb 10, 2008 | 01:47 PM
jaz's Avatar
jaz
Patch from the inside is the safest way to go for sure, but that one is too close to the sidewall. Time for a new tire.
Old Feb 10, 2008 | 02:24 PM
afmafia's Avatar
To Close To Side Wall
Old Feb 11, 2008 | 01:21 AM
Evil9's Avatar
+1
Get a new tire or get a used one. . i Too much of a risk and tire shops. probably wont do it...
Old Feb 11, 2008 | 05:23 AM
Neal@tirerack's Avatar
I'd advise against it. Looks as if the damage is right on the edge of the tread slab where its bonded to the sidewall. Not the best place for a hole as there is a seam holding the tire together there.
Old Feb 11, 2008 | 05:35 AM
ribbie78's Avatar
if you didn't drive on it while it was flat you could try it and see if it holds air. i'd prefer to just replace it. I replaced a 1 week old snow tire this winter on my truck after it picked up some huge piece of metal in it. i went about a block and it destroyed the sidewall.
Old Feb 12, 2008 | 08:45 PM
EatSleepBoost's Avatar
dont risk blowing it out and loosing control and smashing ur car. replace tire. too close to sidewall.
Old Feb 17, 2008 | 02:31 PM
Crankwalked2G's Avatar
You have to patch it, not plog it. Even though it is close to the sidewall and that is no good but there are these patches that we have at work and I have patched few tires at work and so far not have any comebacks. Just go get it patched. The shop should tell you that it is too close but tell him up-his.
