What offset is normally required?
Old Feb 12, 2008 | 06:26 PM
Slo_crx1's Avatar
Just wanted to know what the normal offset is for an Evo 8. I see a lot of wheels that say +30 or +35 that supposedly fit, and I ran across a set of wheels today that I might consider for my car. Only thing is it says the offset is +20, and it just doesn't sound right. What offset should it really be?
Old Feb 12, 2008 | 06:40 PM
beomoua's Avatar
I am not an expert, but I believe the stock offset of the evo 8 enkei's are +38mm. The wheels you want are +20mm, as far as I know those won't fit because they will not clear the brake calipers. the only real way to make them fit is by using wheel spacers to bring out the offset. But 18mm is kind of steep, that's about 3/4" spacer. You would also need longer wheel studs to make them fit. I would just look for a set that is closer to the original offset.
Old Feb 12, 2008 | 06:44 PM
Slo_crx1's Avatar
Yeah, if that's the case I don't even want to try. Was kind of interesting, they're supposed to clear 350z's and g35's with Brembo brakes with that +20mm, hopefully I can find them in a +38mm then. Thanks!
Old Feb 12, 2008 | 07:21 PM
roevo's Avatar
i have an 03 with a 18x9 with a +20 offset, clear no problem with no wheel spacers at all. i have no issues with the front brakes
Old Feb 12, 2008 | 08:32 PM
EatSleepBoost's Avatar
thanks for this post, i was also curious what the stock offset was
Old Feb 13, 2008 | 02:50 PM
Slo_crx1's Avatar
Ok, so if that's the case then these specific wheels with a width of 8.5" and a +20mm offset should fit with no issues then, seeing that the offset is how far the center of the wheel sets out towards the outer lip. Only problem then would be if they stick out past the fender line.
Old Feb 14, 2008 | 12:24 PM
roevo's Avatar
yes the wheel does stick out slightly form the fender, bit i am running a 235/40/18 tire witch has a strech to it.
here is a pic of the wheel on the car
Old Feb 15, 2008 | 10:19 AM
justin44's Avatar
I bought JIC 18x8.5 wheels with a +25 offset and they rub against the fenders. I do have aftermarket springs ...
If you have an option, go with +35 offset
Old Feb 15, 2008 | 10:23 AM
ravellron's Avatar
no its good +30 with 8,5.....
