Any reviews on Ohlins Flag-L coilovers?
Old Feb 16, 2008 | 01:09 AM
ecuflasher's Avatar
Anyone used these coilovers on an Evo before?
Old Feb 20, 2008 | 11:05 AM
ecuflasher's Avatar
Bump
Old Feb 20, 2008 | 12:02 PM
GTWORX.com's Avatar
We and Dave Mac are planning on running the Flags in the upcoming season in STU auto-x. We will be using custom spring rates and custom valving.
- Andrew
Old Feb 20, 2008 | 02:00 PM
RaNGVR-4's Avatar
All I know is the stock valving doesnt have a wide enough adjustment to make it a good daily driver/ track/ auto-x setup. its better siuted to mostly track useage in factory form.
Old Feb 22, 2008 | 04:44 AM
ecuflasher's Avatar
So the flags from the factory are valved 100% for competition usage only? Not suitable for daily driving at all?
Old Feb 22, 2008 | 10:56 AM
RaNGVR-4's Avatar
Its not a good daily driver shock. That doesnt mean it wont work, But its not going to be as comfortable as a revalved set, or something else. On track, im s ure theyre great with correct tuning. If you dont know what your doing with suspension setup, dont go spending 4k+ just cause it looks cool.
Old Feb 22, 2008 | 11:04 AM
GTWORX.com's Avatar
^ Pretty much true. They're not too bad on the street, and they're awesome on the track, but if you're not at the track or autocrossing a lot, your money would be better spent elsewhere.
- Andrew
Old Feb 22, 2008 | 09:24 PM
ecuflasher's Avatar
My usage is around 30% track and 70% street. Would the DFV be a better choice then? I'm moving over from Zeal which was fitted with 14KG rear and 12KG front springs. I find them to be livable on my local roads. My tires are 265/35R18 R-compounds so I reckon I need stiff springs to prevent bottoming out rite?
Old Feb 22, 2008 | 11:44 PM
RaNGVR-4's Avatar
Id say the new DFV is much more suitable for your useage. Your probably going to want something around 10-12k front, 11-13k rear if you want stiff spring rates. with the motion ratios of the evo suspension, to get correct wheel rates, always go stiffer in the rear.
Old Feb 26, 2008 | 08:06 AM
ecuflasher's Avatar
Ok I get you. Stiffer spring rate in the rear will retain the stock motion ratio of the evo suspension. How close should the diff be to retain it? 2KG diff or 1KG? Let's say 10KG in front and 12KG in the rear?
Old Feb 27, 2008 | 01:31 PM
DimitrisIX's Avatar
Have a look here: https://www.evolutionm.net/forums/sh...ht=motion+rate
"the rule of thumb is that your front rate should be around 80% of your rear rate. The stock EVO is just like that (180/225x100=80%).
Some people buy the DFV and swap front/rear springs this will give you 8kg / 10kg. This is 80% of the rear rate which follows the stock rate philosophy. A higher spring rate at the rear is supposed to reduce weight transfer and give the inside front wheel more traction.
As already mentioned, the motion rate of the contol arms is the key factor if someone has calculated the motion rate of the stock evo suspension we would be able to calculate wheel rates (how much of the springs power actually makes it to the wheel) like the 350z guys
have a look at the math:
http://www.my350z.com/forum/showthread.php?t=333627
I think this gives you a better idea because it takes motion rate into account
Old Mar 30, 2009 | 10:25 AM
konstantinosIX's Avatar
Does anyone know where I can I find an English manual for the Flag-L Ohlins ???
Old Mar 30, 2009 | 10:50 AM
GTWORX.com's Avatar
^ Doesn't exist.
- andrew
Old Mar 30, 2009 | 02:27 PM
Originally Posted by GTWORX.com
^ Doesn't exist.
- andrew
Any settings for circuit use???
Old Mar 30, 2009 | 02:35 PM
evoone's Avatar
^ Doesn't exist.
- andrew
how dumb
