sway bars
sway bars
hey guys im looking to help out my suspension a little bit... i want to get coilovers but right now isnt the time. i will be going for my tune soon so im just looking for somehting to help me out in time. think about getting a rear sway bar
i've been looking at the perrin package that comes with new brackets and their endlinks
just wondering if anyone has feedback with their sway bar
Thanks
Thanks
Perrin, Whiteline, Hotchkis are all popular RSB's.
Of course you want to match your RSB to your suspension and all. But a RSB and Springs is a good start. I ran this setup for 1.5 years; Swifts and a Hotchkis RSB.
It's ok if you're not ready for coilovers, but doing JUST an RSB will not improve your handling. Consider a nice set of springs first as well as some bushings and a roll center kit.
Go with good springs like Swift, Robispec, Espelir GT, Works, GTWorx, etc. Hotchkis is nothing special.
Check a few other threads for the recommended bushing kits - they are recommended over and over on threads like these. Mine are from Works, but they came as part of my whole coilover race setup.
all springs drop the height a little. if i get coilovers and set the height the same as stock, and then get a RSB, will that improve my handling? i assume the coilovers are stiffer so that alone would add better handling. is that true?
Thanks
Thanks
a rear sway bar does wonders for handling!!!! i've been runnin Muellerized stage 1 for a year and it is night and day compared to stock... 25mm adjustable sway set to the stiffest setting, rear trailing arm bushings, and a 2.2 neg camber up front, .8 neg on the back... i would never get springs as they are only for appearance and do NOT make ur car handle better
ya my buddy got springs, and that thing understeered worst than stock... just a sway bar and alignment eliminates 90% of your understeer.... Get coils, and it shouldn't understeer at all if ur driving it right
Some springs suck. But not all of them. Don't lump them all together in the same category. Some springs have some actual engineering and design behind them besides "lets drop the car this much."
- Andrew
- Andrew
