Need Help With Brakes!
I HAD to replace my front rotors with new OEM units (no time to order aftermarket rotors) due to all the minute cracks that developed after some serious weekend racing...(previous owner). And I replaced my rears due to lack of material to turn...I went with Racing Brake slotted rear rotors and Hawk HPS pads front and rear.
All around I am happy with my decision. The Hawk pads squeak a bit during light braking at slower speeds coming to a stop...not always...only at times. Front and rear rotors are holding up fine and still have plenty of material left on them. Stopping power/grip is impressive after proper bedding of the pads.
The only time I would even consider turning a rotor is when your rotor is slightly warped - turning helps true the rotor or if your rotor is glazed. Rest of the time my opinion is that it is a waste of money and your rotor material even if you have groves in it.
A crack that continues through the entire rotor surface or it is located on the outer or inner edge on the other hand should immediately be replaced. These types cracks you can usually feel in your brake padal when braking lightly..
I go through at least 1/2 dozen brake pad sets before the rotors are done. You should replace the rotor when they reach min thickness...no need to any earlier.
In most cases these are just heat surface stress cracks and are totally fine. I never had them grow beyond that. You can still use the rotor even without turning it. After a few K miles of street driving, they'd be wiped clean.
As a side note, they hung up one of my rotors on the shop wall of FUBAR'd parts!!
For the most part I agree with what you said......I always turn my rotors when installing new pads....never had issues with this practice.
FS[MidWest]: Binary Engineering Brake Ducts Plus Hose
WarmPepsi
Sep 10, 2016 12:04 PM
TTOPPOUZI
14
Aug 12, 2008 06:57 PM
