Hawk Pads
Doesn't matter - just use a FlexHone no matter which race compound pad (even same mfr) before putting street pads back on; not needed when going street to track pad though.
Dan Law
DER MotorSports
Dan Law
DER MotorSports
this is the first time i'm running dedicated race pads. i thought the pad deposits could be rid off by going thru the bedding in procedure after swapping the pads.
anyways, back to topic, i'm very pleased at how the hps run on street. no complains whatsoever.
cheers.
cheers.
hps worked great for me and dtc 70 front & dtc 70 rear or ht14 front and ht10 rear great also, with hoosier r6 one of my stock caliper burned (front left) at summit point (shanondoa??) a really technical track...
I have Hawk HP+ pads. You guys don't know what noise is untill you get a set of these. However, I still really like them.
I've got a set of Hawk HPS I've thought about putting on just to kill out some of the noise. I'm not sure if I'll do it yet or not because I really like the way these HP+ pads work and feel. Only complaint is the noise... and yes, it's that bad
All in all, Hawk makes a really good product. I've had them on multiple vehicles with great results.
