does this mean i need a rebuild?
Old Apr 12, 2008 | 09:36 PM
evofool's Avatar
I did a lot of searching before i posted this and couldn't come up with a definite conclusion.
i just took off my passenger front caliper and my outside pad looks new and the inside barely has anything left. i had my gf push on the brakes while i watched and one of the out side pistons wasn't moving on the inside. I'm assuming this is the metal on metal noise i heard the last time i drove the car.
i'm going to take all of the calipers off check them, but i'm assuming i need a seal kit. if someone could explain that would be great. the car has seen no track days and it has 55k
Old Apr 13, 2008 | 12:26 PM
evofool's Avatar
took the drivers side apart today and it looks perfect. so i'm assuming i just need a new seal for the passenger side? i'm going to try and warranty it first on monday, better knock on wood...
Old Apr 14, 2008 | 01:04 AM
06WWMR's Avatar
Sounds like the piston seized in the caliper some how... You could probably get away with a rebuild, but then again who knows? Good luck with the warranty.
