Brake Fluid
Brake Fluid
How often are you supposed to service your brake fluid? are there any other fluids i should be servicing? what about the LSD Gear oil...how do i change that cuz i think i have some laying around....
It depends on the brake fluid
If you use sohe high grade it shall be changed maximum after 12 months or sooner if you boil it.
Regarding oils - maximum intervals are in the user guide
But again, if you use the car mostly for racing purpouses shorter intervals are recommended
There should be some 'how-to' on the LSD. I did mine on the clutch job I just did. All you have to do is drain it from the 24mm drain plug on the bottom and then fill it back up using the 17mm fill plug, which is on the passenger side of the transfer case. Make sure to use the correct fluid when doing this. It is the GL5 hypoid fluid sold by Mitsu you want.
