suggestions for sway bars and end links combo?
i am ready to replace the sway bars on her and would like some recomendations on sway bars and adjustable end links. am looking at agency power or h&r rear 27mm bar.what is the difference between between a 25mm and a 27mm rear bars?is their any noticeable difference?will mismatching brands of bars have any negative effects? what setting on a rear adjustable out of the three are most of you guys running?i run scca solo 2 and need to kill the understeer badly but it is my daily driver also.lowered 1.5 at least. thanks for the help guys.
25mm adjustable sway set to the stiffest.... and let me tell you, i am an addicted spirited canyon driver in socal, and i recently just did the works trunk cage and the carbing 6-point underbrace(i also have muellerized stage 1), and holy **** my car has zero understeer and will oversteer before it will understeer... i have an MR btw and after the results of all this i will not spend money on coils... but definatley get a sway bar and alignment!
I upgraded to the perrin 25mm bar set to the stiffest setting on stock MR suspension and this improved my Evo understeer but I really did not like the bends fitment. One side of the bar rubs against my right rear axle and its grinding it down a little. I am thinking about selling it and trying a different brand like agency power.
Anyone have this problem with a perrin 25mm bar?
Anyways, let me know how you make out with whatever bar you end up getting.
Swift also makes a great sway bar set.
My review:
https://www.evolutionm.net/forums/sh...d.php?t=342041
And a nice video from last weekend in here:
https://www.evolutionm.net/forums/sh....php?p=5781160
My review:
i am actually prety curious about sway bars. when i bought my car it was already on lowering springs and aftermarket sway bars. they are blue and im not sure if they are labeled with what company. who makes blue sway bars?? also the stock end links are on there
- Andrew
don't spend crazy money on front and rear endlinks - check here instead
http://www.cs.unm.edu/~donour/cars/evo_endlinks/
Those so-called high dollar aftermarket endlinks are no better than the above (and it's easy to get replacement heim joints for the above too because they do wear out).
