*AMS PRODUCT RELEASE* Steering Rack Precision Kit
Old Jul 11, 2008 | 08:32 AM
AutoMotoSports's Avatar
Designed for our Record Setting Time Attack car and now available to you!
AMS offers our very unique Steering precision kit.
The AMS Steering precision kit takes steering response to a whole new level. Using our suspension and Chassis guru's here at AMS we developed a kit to help top level Drivers take advantage of some Toe changes when pushing their EVO VII/VIII or IX's to the limit
Unlike other steering precision bushings this is made of 100% 6061 Aluminum and CNC'd to extremely tight tolerances.
This part is designed for experienced drivers that have a good grasp on suspension geometry and understand toe changes under compression and droop.
Right off the race car and into yours!
$159.95
Click HERE to ORDER!
Old Jul 11, 2008 | 08:36 AM
EvoIXMR's Avatar
damn it AMS, now you come out with this. After I install the whiteline precision steer kit. This sucks azz. Dropping the subframe is such a PITA too...Grrr!
Nice product as always!
Old Jul 11, 2008 | 11:23 AM
EVOizmm's Avatar
sweet, I'll have to do this while my subframe is out of the car!
Old Jul 11, 2008 | 04:21 PM
EVOlutionary's Avatar
Originally Posted by AutoMotoSports
. . . we developed a kit to help top level Drivers take advantage of some Toe changes when pushing their EVO VII/VIII or IX's to the limit
So does this kit change the location of the rack (raise or lower it) to change the "toe curve", or does it just solid mount the rack so your toe change under suspension compression is more predictable??
Old Jul 15, 2008 | 08:01 PM
Cruiserdude's Avatar
x2
Old Jul 15, 2008 | 10:05 PM
EricJ@AMS's Avatar
It does not change the position of rack.
Old Jul 21, 2008 | 07:14 PM
If it does not relocate the rack higher, then how does it :
. . . help top level Drivers take advantage of some Toe changes when pushing their EVO VII/VIII or IX's to the limit . . .
and what do you mean by :
. . . This part is designed for experienced drivers that have a good grasp on suspension geometry and understand toe changes under compression and droop.
The first part of that makes it sound like this unit allows you to dial in MORE toe change under compression and droop. With it being a stock location solid mount it should allow less toe change and make what change you get be more linear and predictable.
Have you looked at changing the location of the rack a tad higher or lower to actually change and improve the bump steer curves for a lowered race car?
Thanks!
EVOlutionary
AutoMotoSports
Automotosports - Illinois
Sep 4, 2008 06:47 PM
AutoMotoSports
Aug 16, 2008 01:36 PM
AutoMotoSports
Jul 3, 2008 09:44 PM
AutoMotoSports
18
Jun 2, 2008 06:27 PM
AutoMotoSports
Apr 28, 2008 08:18 PM
