Wheel question
Old Jul 19, 2008 | 06:07 AM
03redtype-s's Avatar
Wheel question
Hey guys just checking but an 18x8.5 with a +30 offset will work right? im thinking these will with no problem. Let me know thanks alot! with a 245/45/18
Matt
Old Jul 19, 2008 | 08:43 AM
Warrtalon's Avatar
It depends on the actual rim. Size and offset are not independent of rim style.
Also, 245/45-17s are generally not recommended, but 245/45-18 is even BIGGER (diamter-wise), so you should make sure you know what you're getting. That size tire has a 5% difference in diameter, which will make your gearing much taller and throw off your speedometer while being much tougher to fit in the wheelwell. You would want something like a 255/35-18.
Old Jul 19, 2008 | 03:52 PM
lancer evo8's Avatar
Agreed, your car will have taller stance with tires that look too big and look off. Back to your original question, it depends on the spoke design and if it does fit, you might have to roll your fenders in the rear if you want to rock those tires.
03redtype-s
For Sale - Wheels / Tires
Apr 11, 2016 05:58 AM
03redtype-s
Nov 29, 2015 10:27 AM
03redtype-s
Oct 8, 2015 05:01 AM
03redtype-s
Feb 21, 2012 11:09 AM
03redtype-s
Mar 27, 2008 10:10 PM
