Why do spacers help wheels fit?
You can't just throw out a random number without backing it up with either hard data or first hand experience. . .
There are a plethora of folks who use 25mm or larger spacers in racing applications all the time with no problems. And racing on slicks will put MUCH more force to the wheel and hub than a daily driver on street tires. . .
EVOlutionary
Can you please provide some engineering data to back up your recommendation of "10mm spacers max" ??
EVOlutionary
EVOlutionary
No idea where you heard that silly info.
EVOlutionary
EVOlutionary
I am using 25mm custom hubcentric T6061 spacers in front with the ARP extended studs. I am able to get more than 10 full turns on the studs so I reckon they are tight enough. However, I'm still not sure if I can trust this setup to hold up under real racing with 265/35R18 slick tires
As long as your wheel spacers are hubcentric, they will not impart any abnormal load to either your hubs, wheels, or studs.
I run a similar setup - 15mm hubcentric spacers, 285/30/18 Hoosier A6 tires, ARP studs, Kics lug nuts. Been using the same lug nuts for 3 years, and the same wheel studs for 2 full years of autocrossing. We see up to 1.45 G's lat accel. . . and never had a single issue. . .
(one other thing to consider is that CCW, a top American racing wheel manufacturer, ships many of their wheels WITH spacers)
Evokid03
Jan 22, 2010 10:35 PM
