Need help with suspension!
Old Aug 12, 2008 | 04:30 PM
RPRalliart04's Avatar
Ok, so lately whenever I take off slow from a stop I hear a clunking noise coming from the front of the car.... and now all of a sudden (yesterday) I start hearing a loud clunk sound every time I hit a bump or take a left turn anywhere from 5-30mph. I was clueless on what the clunking noise could have been until yesterday, and now I am pretty sure that noise is blown front right strut.
But my question is.... after searching and reading threads of similar noises now I think that it may also be my endlinks? I am not sure, because the noise that started yesterday definitely sounds like a strut, but because of that problem I have had with the noise could be be the endlinks also?
I tried taking off my front wheels and pushing/pulling the front sway bar and there is a little movement, but nothing major. Should there be any movement at all?
I just would like some help from expertise and experience because either I can replace the endlinks or buy a new strut (or possibly an entire new strut spring set up for the car). Any advice would be awesome, thanks guys!
Old Aug 12, 2008 | 06:00 PM
1d10t's Avatar
Your endlinks have joints that are similar to ball joints. Look to see if there are any tears in it or grease leaking out.
Old Aug 12, 2008 | 06:44 PM
When i looked at them they seemed fine and had no grease anywhere..... I am really stuck here, and its driving me insane!
Old Aug 12, 2008 | 07:01 PM
revvin9k's Avatar
Upper strut mounts.
Old Aug 12, 2008 | 11:14 PM
So would I need to replace both the strut and the upper strut mount? Also, where do i get the passenger side mount?
Old Aug 13, 2008 | 04:20 AM
revvin9k's Avatar
You have to confirm what it is first before you start replacing things. I had the same scenario as you, it wound up being the upper strut mounts.
