need help with rim fitment
whats going on guys? need some help with rime fitment, have a friend selling me some rota P45R's in 18x9.5 with 35offset. my question is will it fir a evo 9? would it rub would i need spacers or do i need a fender roll/pull? and what size tire can i run with these? any info help is appreciated thanks guys!!!
The P45R 18x9.5 +35 wheel will not clear Brembo brakes in the front. You can run this wheel in the rear however you will need a P45R with a +25 offset to clear the front Brembo calipers. You could use a 10mm spacer with the full set of +35 wheels.
-Dan
-Dan
