Swift Spec R advise needed
Old Aug 30, 2008 | 03:37 PM
zaf's Avatar
zaf
Can anyone advise me if my Swift Spec R springs are the correct ones for the MR.
On the box it says 4M017R and there is also a sticker on the rear springs saying
4M017RS but on the front springs the stickers say 4M008RS am i right in thinking that the fronts are GSR springs or are the GSR and MR front springs the same?
Old Aug 30, 2008 | 03:47 PM
Smike's Avatar
Front: 4M008R
Rear: 4M017R
Fronts are the same GSR to MR, the rears are different.
Old Aug 30, 2008 | 04:06 PM
zaf's Avatar
zaf
Thanks for the information and quick reply.
I have one more question if you could answer it for me that is do i need to cut the bump stops on my Evo MR when fitting these springs?
p.s if the bump stops are already cut do you think i should fit new ones?
Old Aug 30, 2008 | 04:08 PM
Smike's Avatar
Anytime.
Yes, cut one notch off. I believe there are instructions in there that will show that also.
Old Aug 30, 2008 | 04:25 PM
zaf's Avatar
zaf
In the intructions there is no mention of cutting the bump stops for the Lancer Evo CT9A it only has Mitsubishi Lancer CS6A with a spring part number 4M903 that needs to be cut. Do you think i should cut the bump stops??
Old Aug 30, 2008 | 04:47 PM
Smike's Avatar
I cut one notch off my fronts.
Old Sep 1, 2008 | 07:59 AM
Kracka's Avatar
Its not needed for the Swifts, but really won't hurt anything if you cut them.
Uhuru
Jun 16, 2015 06:34 PM
CRONZ305
17
May 10, 2014 04:57 PM
math399
Mar 22, 2012 09:58 PM
BrakeOptions
Evo 'For Sale' Suspension / Brakes / Handling
54
Feb 4, 2011 08:20 AM
fitbikedominick
Feb 2, 2009 07:58 PM
