Help Wheel Hop
Help Wheel Hop
so i got my car back from my trans. rebuild and new clutch, it's been about 900 miles since i got it back. and when i am in 1st gear pound the gas, i hear tire screaching noise whenever i shift. i have very light mods, nothing hard core. any suggestions?
niiice who did your trans rebuild, what build did you do and how much? also what clutch did you go with? Just curious because I wanna get my trans rebuilt soon too from 5th gear grinding at fast shifts. To reduce wheel hop, people usually recommend
doing the front motor mount which you'll see the biggest improvement. but if you do all three the better it is. just more vibration in the car but manageable and more enjoying after mounts are done during shifts.
The new clutch is helping power get to the ground faster which is why you're getting tire noise after shifts. Get a poly front motor mount though; great product and easy to do.
TRE did stage 2.5 about 1500, shifts clean no grinding whatsoever!
where i can buy this anybody got a link, i assume the motor mount is weak as hell, this is the 4TH Time trans is pulled out and installed in the car
