Brake lines
Subscribe
Oct 9, 2008 | 02:33 PM
i just install all 4 stainless steel new brake lines in my 03 evo 8 i bled the brakes drove had no brake pedal so i went home did it again i still have to brake preasure any one know what it could be i was told the master took a crap so im going to replace that but can the stock master preasure all 4???
Reply 0
Oct 9, 2008 | 02:38 PM
Assuming you topped off your brake fluid level?
Any leaks on the ground?
Reply 0
Oct 9, 2008 | 04:35 PM
nope no leaks im thinking my brake master took a crap they only make stock ones right like no aftermarket ones to push more pressure
Reply 0
Oct 11, 2008 | 01:58 AM
Did you push some fluid out of the system with the car running so the ABS would cycle? Also the Evo uses an odd brake bleeding sequence. You should be able to find it with a search - I've posted it a couple of times and have seen it posted by others as well.
Reply 0
Oct 12, 2008 | 08:40 AM
Chances are the MC isn't bad if it worked fine before you changed the lines.
I did my rear lines first, bled them. Moved on to the front, bled them and everything works fine.
Reply 0
Nov 3, 2008 | 12:22 PM
im stupid it was the inside bleeders on calipers i didnt bleep its all great now haha nice hard pedal
Reply 0
Nov 3, 2008 | 12:39 PM
Reply 0
Nov 4, 2008 | 05:19 AM
Quote: im stupid it was the inside bleeders on calipers i didnt bleep its all great now haha nice hard pedal
if u search with my name, u will see i did the same thing too
its a relief that its all good now right, lol
Reply 0
Subscribe
