Brakes Help!!!!!
Old Oct 17, 2008 | 06:59 PM
rooney08's Avatar
Unhappy Brakes Help!!!!!
I bought 4 cross drilled and slotted rotors and pads from Brake planet's ebay page, they have been squeaking ever since day one, I also get a lot of brake dust, I always tought with cross drilled and slotted rotors you werenot supposted to get so much brake dust, u think it has to do with the brand, any suggtions out there, I am really frustated with the squeaking and all the brake dust. thanx a lot.
Old Oct 18, 2008 | 05:25 AM
slvrr's Avatar
Hmmm I've never heard of slotted/drilled brakes helping with brake dust..That is souly your pads and has nothing to do with your disc's. Did you put the OEM hard ware back on? You really should have done more research before buying your brakes, this is an important part of driving and you can never be too carefull
Old Oct 18, 2008 | 06:36 AM
garcias2k's Avatar
Do you know if they are ceramic pads? They are better for less noise and dust. Also spraying the back of the pads with some disc brake quiet. It's a blue sticky spray that helps prevents the pads from vibrating.
Old Oct 21, 2008 | 05:39 AM
rooney08's Avatar
somebody mentioned that it may just be pads last month when I drove my car to AMS, they told just to get some hawk brake pads and that should take care of the squeaking and brake dust, when I bought the discs they came with the pads, what kind of discs would u recommed? slotted & drilled? slotted? what brand? thanx a lot.
Old Oct 21, 2008 | 05:45 AM
rooney08's Avatar
I pretty sure they r ceramic pads they came with the rotors, where can i get the spray? I've looked at auto zone & napa and they said they do not have it. The steering wheel on my evo now is also vibrating a lot when I driving over 45 mph and then suddenly brake, do u know if these is an indication of warp rotors?, mine are not even a year old. Thanx a lot for ur time. By the way hablas espanol?
Old Oct 21, 2008 | 05:47 AM
EvoHung's Avatar
When you had the brakes installed, did you remember to apply high temp grease behind the pads? If not, that could be the cause of your squeaking issue. With the brake dust, thats just normal...unless you have a more than average amount than it could probably be due to the combo of having slotted/drilled and the pads, or the pads just have high brake dust. The brake experts will recommend that you don't need slotted/drilled rotors. Blanks should be plenty good for road and track use.
Old Oct 21, 2008 | 06:01 AM
rooney08's Avatar
I don't recall applying any grease to the pads, only thing I did was clean the rotors with the spray cleaner, so what are slotted or drilled rotors recommended for? I mean what is the point of buying them? thanx a lot.
Old Oct 21, 2008 | 06:13 AM
xtnct's Avatar
You have it backwards. From: http://en.wikipedia.org/wiki/Disc_brake
Originally Posted by http://en.wikipedia.org/wiki/Disc_brake
Discs may also be slotted, where shallow channels are machined into the disc to aid in removing dust and gas. Slotting is the preferred method in most racing environments to remove gas, water, and de-glaze brake pads. Some discs are both drilled and slotted. Slotted discs are generally not used on standard vehicles because they quickly wear down brake pads; however, this removal of material is beneficial to race vehicles since it keeps the pads soft and avoids vitrification of their surfaces.
In other words, the slots are there to cut the surface of the pads. This means increased pad wear and obviously more dust than a solid rotor.
Old Oct 21, 2008 | 06:14 AM
MondoBongo's Avatar
they are slightly lighter than regular rotors, but by far their largest benefit is that they dissipate heat much, much better. allowing them to work better, longer, without as much fade.
Old Oct 21, 2008 | 06:34 AM
xtnct's Avatar
Here you can find what the benefits are supposed to be (but they don't list the negatives):
http://www.drilledrotor.net/
This basically summs it up in the real world (as opposed to the theoretical one):
Originally Posted by http://www.tirerack.com/brakes/tech/techpage.jsp?techid=79
The first step is to determine what type of brakes you have on your car now. Then assess what you would like to improve, along with any tradeoffs you are willing to make to gain the things you want more of.
Old Oct 21, 2008 | 06:37 AM
Mr. Evo IX's Avatar
Mostly for Looks, drilled and slotted rotors will most likely crack under heavy use. Slots are supposed to help clean the pads and drilled rotors are supposed to help dissapate heat, but I've never had a problem with regular blanks so thats what I prefer. Every set of crossdrilled rotors I've seen that were not OEM had cracks.
https://www.evolutionm.net/forums/sh...rotors+cracked
When installing pads on the Evo, apply liberal amounts of high temp grease on the backs of the pads and both sides of ths shims, pins, etc. But if you have hawk pads then your gonna squeak anyhow.
