Alinement specs?
Old Nov 6, 2008 | 07:35 PM
importjake00's Avatar
Alinement specs?
After my car is fixed from an accident, I am going to get an alinement and want to know what specs people are running.
I do not race the car, and it is my DD, so I was thinking about just stock, but I figured I would find out what others are running.
Old Nov 6, 2008 | 07:36 PM
Clutchdc5's Avatar
id also like to know this, i want to save my tires in these harsh times
Old Nov 7, 2008 | 10:59 AM
jid2's Avatar
-1.25 ish front camber, zero toe (or a touch of toe-in to save inside tire wear), -.75 camber rear zero toe. That's a good street alignment.
Old Nov 11, 2008 | 11:09 PM
Anyone else?
Old Nov 11, 2008 | 11:13 PM
Pure EvoIX's Avatar
camber -2/-1
toe 0/0
semi aggressive street alignment.
Old Nov 12, 2008 | 12:17 AM
dbsears's Avatar
^^Thats what I run. Tad more in the rear I believe. -2f and -1.2R, 0 toe. Have 9k miles on my RE01R's with 5 track events and perfect wear. Just max out the stock camber bolts...only usually gives -2 degrees in the front. Just make sure the toe is zeroed out, thats what wears the tires.
Old Nov 16, 2008 | 08:47 PM
groundzero1v's Avatar
so, i was looking at the stock specs and why is the front camber selectable to either -1 or -2?
Old Nov 17, 2008 | 10:56 PM
What is the stock specs?
Like dbsears said, I am thinking about going with -2/-1/0
Sound good?
Old Nov 18, 2008 | 09:37 PM
huevosrancheros's Avatar
Originally Posted by Pure EvoIX
camber -2/-1
toe 0/0
awsome setting.
Old Nov 18, 2008 | 09:42 PM
would those setting wear my tires down any more than normal?
Old Nov 18, 2008 | 09:46 PM
Billy@EnglishRacing's Avatar
I would ask Aaron this weekend and go with whatever he says
Old Nov 18, 2008 | 09:55 PM
I asked him when I was down at ER and he wrote it down for me.. but i lost it, and I do not want to bug him again about it..
Old Nov 24, 2008 | 07:04 PM
Anyone else?
I am going to get an aliment friday, want to get the best I can!
Old Nov 25, 2008 | 04:45 PM
SoCal Rally's Avatar
I believe stock Evo alignment settings are:
Front:
Toe-in mm (in.): 0 +/- 2 ( 0 +/- 0.08)
Camber (Selectable from 2 options): -1deg +/- 30' or -2deg +/- 30' (left/right deviation within 30')
Caster: 3deg55' +/- 30' (left/right devitation within 30')
Rear:
Toe-in mm (in.): 3 +/- 2 (0.12 +/- 0.07)
Camber: -1deg +/- 30' (difference between right and left within 30')
So for a daily driver, I would do:
Camber: -1.5F, -1R
Toe: 0F, 1/16" toe in R for stability
