I need help.
I need help.
Ok heres the story. I hit a side walk head on with a slight angle to the right. So the front left tire hit the side walk first. The hole car crossed the side walk. when I took it to the dealer they said i had to change my left lower arm and my front right hub and wheels. So i did. I had problems finding the parts cuz the dealer didnt have them all so I got a freind to get the hub from his local dealer. the car is fixed now and it runs great. But I have a problem thats driving me crazy. My front right wheel is not in the place its supposed to be, its pushed alittle inside towards the engine. The dealer says that they cant see anything wrong when looking under the car and they cant figure out what the problem is. I recently changed my left lower arm thinking it might be bent and we cant see it but nothing changed. I have buddy club coilovers with camber adjustment plate. When I aligne the car i have to add more camber on the camber plate on the right than left to get the same camber on both sides. The dealer also says that theres no problem with the chassis. On a side note i think that the hub my freind got me from his dealer might be an evo viii hub. will that make a difference? what do you guys sudjest i check or do to fix this problem. Thanx
