alignment issue
Old Nov 18, 2008 | 05:55 AM
whitedsm97's Avatar
alignment issue
i recently bought some oem struts/shocks to use for winter because i didn't want to drive in the winter with the jic's that were on there. now i put them on and my steering wheel is crooked. the car pulls to the right but the steering wheel is off to the left a little. i'm the second owner and not sure if an alignment was done to cooperate with the jic's. also it had some wedsport rims that were 17x9. any ideas would be helpful.. thanks. i'm going to take apart and look again. also, does it matter which shock goes in the front like one is for right or left. thanks.
Old Nov 18, 2008 | 06:04 AM
ROAD RACE VR-4's Avatar
Every time you replace suspension components (springs/shocks/tie rods/ball joints) you have to take your car to an alignment place.
Old Nov 18, 2008 | 04:43 PM
kekek's Avatar
Your car MUST be aligned. Camber and toe change throughout suspension travel and the settings used at a lower ride height will not be the same at a higher ride height.
Old Nov 18, 2008 | 04:48 PM
fugiwara's Avatar
how can you expect the alignment to be the same after removing changing the struts/shocks?
also, the front camber bolt can change the camber from -1 to -2
Old Nov 19, 2008 | 05:32 AM
whitedsm97's Avatar
i'm not expecting it to be aligned, i was wondering if that's normal. the car does seem to sag on the passenger side more and it pulls to the right if i let go of the steering wheel.
akride907
Mar 17, 2016 02:13 PM
VinnyV81
15
Jan 29, 2013 11:13 PM
evo_skillz
Jun 16, 2012 11:24 AM
JDMevoBOOST
Sep 8, 2011 03:01 PM
evilbada
Apr 19, 2008 04:27 PM
