I need with wheel size. PLEASE
Hello, I really need help about what are the exatly size that i have to put on my evo 9 with using "SPACERS".
I bought ruff wheels a year ago I think the offset was 15mm or something like that, and when i tried to intall them, the front brakes toched the wheel, so I had to buy a 25 mm SPACERS....
That was the worst thing I did because my steering wheel shakes like crazy. I did aligment, I check every thing, but every body are telling me the same thing, the spacers are making the shaking..
I have 19" I would like to keep that same size, but i do not know if that matters with the offset....
Please I NEED HELP.
Note: Sorry for my english I am learning it.
Please I NEED HELP.
You are likely needing hubcentric rings/spacers. The rings put the wheel exactly on the hub and help keep the shakes down.
If you can post the exact wheel model you have, I bet someone can track down the hub size and tell you what kind of ring you need.
Or contact one of the many vendors on here (Touge Factory, Darkside Engineering come to mind as ones with a good deal of wheel/spacer/ring knowledge).
