Wheel Stud Help pics
I'm trying to replace my wheel studs with the ARP ones and I'm stuck on the back ones. The front I have done but I cannot get the rear bolts in. I was able to get the stock ones out by wiggling them around tell the fell out but the new ones are longer and wont fit in. here are some pics to help explain what i mean
and a shot of the new wheels
ok e-brake is apart but i cannot get the dust shield off because it is tac welded on. i tried removing the 5 bolts behind the hub and the big gold center bolt with all of them off it still wont budge or pop off. i will go take another picture to show what i mean
i removed the 4 bolts holding the hub assy on and it will not budge at all. im afraid to hit it with anything to break it loose. i have been spraying it with pb blaster for a few days and still no luck
i did 10mm spacers on my X last week. Had a similar problem with the rear, but with the 4 bolts undone on the back of the hub the hub could slide out slightly and we could get the studs in there. Took a little work but it worked, I know the ARP ones are pretty long, so you might have to completely remove the hub somehow. GL.
This is the type of tool you need.
http://www2.northerntool.com/auto-re...tem-153901.htm
I have no idea how much force you can apply until it damages the cv joint/axle. Mine have never required a whole lot. The center piece will push against a chamfered hole in the end of the axle so the nut being present is not necessary. You'll probably have to trim the ends on the pullers to fit between the ebrake pads and the hub.
You need a slide hammer type puller that attaches to the studs but the studs are out so put three back in and pull the wheel hub.
From the manual;
Use special tools MB990244 (MB990241), MB991354 and
MB990211 to pull out the rear wheel hub from the knuckle.
From the manual;
