Lowering Springs question
Old Sep 11, 2003 | 09:11 AM
BLKEVO8's Avatar
I am considering lowering springs, I see that H&R has some but they drop 1.4, 1.3 rear it seems a bit much Ralliart has some but only drops .5 would I run into problems with 18x9 245/40 wheel set up with the H&R and has anyone done only a spring drop? I have already done a search and nothing came up that would help me.
Old Sep 11, 2003 | 11:44 AM
G20's Avatar
G20
I have Eibach and like it very much. My car dropped about 1 inch. I noticed better handling too. The only catch is I have to be careful to go slower when existing deep drive way.
Old Sep 11, 2003 | 01:34 PM
PnutButterWolf's Avatar
w/ lowering springs, you might need to roll the fenders (especially the rear fenders) a little bit since you are using 18x9 w/ proper offset.
Or go JDM style, 18x9 or 9.5 in front and 18x8.5 in the rear w/ 245/40/18 tires.
Old Sep 16, 2003 | 10:32 PM
timzcat's Avatar
Even though the tire size is the same, a difference in width (espeically an inch) will affect tire height due to the positioning of the sidewall in comparison. This will affect the outside diameter of the tire and ultimately that is not good for the center diff.
Old Sep 16, 2003 | 10:37 PM
RoundPro's Avatar
i have the Eibach springs and 18.9's with 255 45's PS03 and i recommend this set up. Still need sway bars.
