Rim/Tire/Offset Question.....How big?
Old Jan 1, 2009 | 05:29 PM
vegasse's Avatar
I'm sure the answers are around here somewhere but 30 min of searching and reading haven't found them.
What is the widest rim/tire combo I can run on the APR widebody rear fenders and at what offset?
What is the widest rim/tire combo I can run on ChargeSpeed widebody front fenders and at what offset?
The car has 265/30/18's all the way around on 18x9.5's but I'd like to go wider on both front and rear. Obviously I will need new rims. I assume there is a way to fit 315's on the rear and 275's up front. I just need to know what offset will accomplish this on a set of VOLK GTF's. Thanks!!
Old Jan 1, 2009 | 05:32 PM
Smike's Avatar
For AXing for TTing?
You should be able to stuff in 275/30/18s right now with some light hammering, pulling, and rolling.
I am not a fan of staggering sizes on AWD cars.
Old Jan 1, 2009 | 05:35 PM
vegasse's Avatar
Well my Gallardo has 295's on back, 245's on front with Hoosier R6's making 1016awhp and I'm not having any issues.
I should add I want the tires not to stick out AT ALL. As long as they are flush with the top of the fender lip, I'm good with that.
Old Jan 1, 2009 | 05:40 PM
Smike's Avatar
Its an Evo v. Gallardo. To move those steam rollers your Evo must have a few ponies too.
I seriously doubt you will be able it fit all that wheel in there with out tubing or much wider fenders. Those fenders extend 10-20mm correct? You can get wider front fenders also. To know how much you will need to extend the fenders you will need to either mock-up a set of wheels and tires and measure or find someone thats done it...the latter might be harder.
Old Jan 1, 2009 | 05:46 PM
vegasse's Avatar
True. The Evo, at 600awhp spins the tires pretty good in second and third on 8200rpm shifts. I'd like a little more traction in the rear. In truth, I think 295's would do the trick with the bump up to 700awhp which is the next step. BTW, yes the fenders are 20mm. I have the fronts done already and will be doing the rears shortly. The 265's fit on the rear right now with rolled fenders. I'm going to be doing a widebody rear shortly, so hopefully at LEAST a 295 will fit.
