Worst grinding sound evAR!
Old Feb 25, 2009 | 01:17 PM
smp3000's Avatar
Ok, so my passenger side front brakes sound terrible and have for a few days. I have new rotors and pads on the way- as they need changed anyway, but is there a chance it could be something with the caliper?
The sounds is almost as if I have no pad at all left, but I do... And it even continues to make noise when I'm just driving and not applying the brakes. I was told it could be that one of the sliders is stuck?
I don't know much about brakes other than pads and rotors, so this slider thing got me confused.
Any idea?
Old Feb 25, 2009 | 01:20 PM
Evolution7GSR's Avatar
something must be stuck up in there somewhere..... maybe a rock behind a heat shield or something?
Old Feb 25, 2009 | 01:22 PM
1320 Engineering's Avatar
eww i had that, ended up being a rock in the brake pad... who knows how it got there lol
Old Feb 25, 2009 | 01:24 PM
Majuljo's Avatar
i dont know man on my old car my brakes and rotors were toast and when i drove the car it sounded like an airplane was landing lol. change it first and if it still has the same noise then it might be the caliper.
Old Feb 25, 2009 | 01:40 PM
goofygrin's Avatar
mine was the heat shield had bent (well not magically on it's own, I did it) and was touching the rotor. No major damage, but it sounded like my car was going to fall apart.
Old Feb 25, 2009 | 01:48 PM
smp3000's Avatar
yeah it sounds realllll ghetto, I'll take a look at it tonight. Thanks guys!
Old Feb 25, 2009 | 05:51 PM
smp3000's Avatar
So I took the pads out and found the problem. The outside pad still had a TAD left, but the inside was shattered and gone completely!!! The inside of the rotor is fubarrred. I cleaned everything off and put what was left back and wanted to test it... But aparently there's air in my brake line- I took off the brake line becuase I was going to take off the rotor and ended up not- so now I have air in the brake line and need to bleed it out... I've just never done it before. Do I have to do it for all of the calipers 2 bleeder valves on each? Or can I just do the two on the caliper I was working on?
I guess I'm just not sure how to get the air out without getting brake fluid all over? I saw the tutorial to fully bleed your brakes- but all I want to do is get the air out of the line.
Old Feb 26, 2009 | 09:56 AM
barneyb's Avatar
First, you don't have to disconnect any hoses to pull the rotor. You can set the caliper up on the suspension - maybe wire it there so it won't fall.
For bleeding use a piece of vacuum hose on the end of the bleeder. Open bleeder - pedal down, close bleeder - pedal up. It is a two person job. When you have a steady stream of fluid, the air is out. You may also immerse the end of the hose in some brake fluid and watch for bubbles. Don't run the master cylinder dry or you will be starting all over.
Old Feb 26, 2009 | 10:00 AM
goofygrin's Avatar
There is a specific order to bleeding the brakes. I can't find it right now, but someone will chime up with it. You only crack the top nipple, never the bottom.
Looks like you're going to need pads and rotors. I suggest getting stainless brake lines and flushing the brake fluid while you're there.
Old Feb 26, 2009 | 10:02 AM
delongedoug's Avatar
Check the DIY section on how to bleed your brakes. It's in there.
Old Feb 26, 2009 | 12:04 PM
smp3000's Avatar
yeah I found the order, but if there isn't much air in there and I only had the line off for a few minutes- could I just bleed the two valves on the caliper I worked on? Or is it essential I do the entire system?
Old Feb 26, 2009 | 12:13 PM
GTLocke13's Avatar
Do the whole system. You should bleed your brakes every time you change pads anyway. And you should flush the whole system every couple of years or so.
This should be a lesson to other people on here. Don't assume that just because the outside pad isn't gone it means the inside pad isn't gone.
Old Feb 26, 2009 | 12:16 PM
gsrboi80's Avatar
Seen this is quite a few EVOS all on the OEM Brembos
Old Feb 26, 2009 | 12:17 PM
smp3000's Avatar
OK, and yes VERY true... The outside pad looked fine- low, but fine- little did I know the inside had completely shattered and the rotor completely rocked...
Old Feb 26, 2009 | 02:57 PM
fostytou's Avatar
EvoM Community Team
Mine didn't make it quite that far, but when I pulled my front pads the inner one was about half as thick as the outer pad.
