Help with caster/alignment
Old Feb 25, 2009 | 02:22 PM
ImJoey's Avatar
Can caster be adjusted on Stock evos? I searched. No solid response.
Old Mar 1, 2009 | 06:32 PM
huevosrancheros's Avatar
yes,
street alignment specs for evo
-2 camber in front, zero toe( has to changed manually for negative camber)
-1 camber in rear, zero toe.
Old Mar 2, 2009 | 12:49 PM
ImJoey's Avatar
Thanks for the response.
Old Mar 2, 2009 | 01:08 PM
Mr. Evo IX's Avatar
OP is asking about Caster adjustment not camber. I dont believe the Evo has any caster adjustment in stock form. If you had a Caster/Camber plate then you could adjust caster.
Old Mar 2, 2009 | 09:59 PM
Murf's Avatar
No caster can not be adjusted on stock evos.
yarlasasi
Feb 25, 2015 01:06 PM
Cudi
14
Apr 24, 2013 08:16 PM
Evolved X
10
Oct 5, 2010 03:58 PM
FAST RS
Jan 14, 2010 08:22 PM
EVOlutionary
Jan 9, 2008 07:04 PM
