What suspension bushings to replace?
I am replacing the factory camber link bushings this weekend and I figure I might as well replace a few others while I am at it. I know I want to replace the lower shock mount bushings but I was also thinking about a bump steer bushings from works but it says they also have the rear toe control bushings available for those with lowered ride heights and/or looking to alter suspension geometry. Not really sure what they mean by looking to alter suspension geometry. Do they men running more neg camber etc? Not really looking for that as I am on stock suspension. Also can you guys suggest some bushings other than the ones I mentioned that may be a bit more beneficial to me? Thanks
The shock mount bushings are a good one.
The 3 I like to replace the most are, in order:
Whiteline Front Control Arm Bushings
Whiteline Bumpsteer Correction Bushing Kit
Whiteline Rear Trailing Arm Bushings
The more bushings replaced the better, but IMO these are the first 3 to replace. BUT the shock mount bushing is nice too.
- Andrew
- Andrew
