Front clearence Help!
I just installed H&R 38mm (1.5") spacers for my slicks to clear wilwood calipers. Well, now when I turn the wheel hits on the sideskirts and will tear them off if I turn more than an inch or so. I was wondering if there is any way to get more clearance at the bottom for the fender by the door? I may have to grind the calipers off more and get more clearance to run a smaller spacer. These are stock size wheels hitting. My slicks do the same thing, they are wider but hit in the same spot.
Any help is appreciated.
