fitment help with 18x9 + 20 offset
Old Mar 28, 2009 | 07:49 PM
dtrackstar's Avatar
I'll be lowered on swift sport springs. I was wondering if 18x9 +20 will fit? If so, what tire size? Would I need spacers (front/back)? Fenders need to be rolled (front/back)? The rim has a 4.7 inch lip, not sure if that makes a difference (I assume the offset already accounts for that?) Are there any other rim specs I need to keep in mind when fitting it? Thanks in advance
Old Mar 28, 2009 | 08:06 PM
TwStDeVo's Avatar
im interested about this as well, btw, what wheels are you running?
Old Mar 28, 2009 | 08:11 PM
dtrackstar's Avatar
Stock now, havent got them yet. need to make sure it will work 1st. They are called Axis widetrack. They're a little heavy but I plan to get light tires to compensate
Old Mar 28, 2009 | 08:21 PM
eve-slow's Avatar
You should have no problem running them. You'll be sticking them out over 30mm further, but you'll gain inner clearance. You'll be best running 235 or 245 tires and will need a rear fender roll.
Old Mar 28, 2009 | 08:27 PM
dtrackstar's Avatar
do you think i'll need spacers in front?
Old Mar 28, 2009 | 08:44 PM
TwStDeVo's Avatar
definitely post pics if you get them, cant believe they have a 4.5 inch lip! lol
Old Mar 28, 2009 | 10:47 PM
BenJ's Avatar
not sure on the spacers on the front, but as stated above, you will need some rolling in the rear. I'm running +22 all around and did not require spacers up front.
Old Mar 28, 2009 | 10:54 PM
dtrackstar's Avatar
thanks, is there any other info needed about the rim to determine if it will fit?
Old Mar 30, 2009 | 12:00 PM
dtrackstar's Avatar
so a 245/40 or 245/35? 235/40 or 235/35? any other suggestions?!
Old Apr 12, 2009 | 11:35 PM
MattevoVIII's Avatar
im doing the same stock+springs 18.x9.5 +20 245/40/18 re01 or rt615
should fit with slight adjustments and rear roll
Old Apr 14, 2009 | 07:06 PM
dtrackstar's Avatar
i asked the manufacturer and they said it wouldnt clear the brakes : ( ... really nice rims for the price... http://axiswheels.com/wheels.php?id=widetrack
