Issue.. just replace rotors/lines/pads
I recently installed drill/slotted rotors with new hawk pads and some stainless lines.
For some reason my brake pedal is very very mushy. I have bleed and rebleed the lines. I have put 2 bottles of motel 600 through the damn brakes and cannot get a firm pedal.
Does anyone have any ideas whats up??
I have checked for leaks on the new lines. I do not see any wet fluid near where the lines connect.
what pads did you use? if you are using track style pads the pedal will feel squishy untill they heat up.
if not try bleeding with superblue so you can be sure you are getting fresh fluid and removing all air to all corners
I only bleed the outside ones. Ill have to bleed the inside bleeder tonight..
Im using HAWK HPC pads.
I saw the inside bleeder but didnt bleed it. I'll give that a try with some super blue.
motul > super blue
But make sure you bleed in the right order or else you'll still have air in there. I can't find the order diagram, but it's not quite as intuitive as you'd think.
no offense to the op but i dont think someone that doesnt even know to bleed the inside and outside bleeder of a caliper is going to to be driving in a situation were he will even register a difference in using motul over super blue. save some money, super blue is half the price pluse it helps with bleeding and they make an amber color one with the same specs you can use to bleed the brakes at the next interval to make sure you have fresh fluid again. all he did with the first 2 botlles of 600 is waste 30 bucks
jeff
jeff
jeff
and BTW, if you read the install guides, none say you need to bleed the valve on the inside.
Also, what I've noticed is that the pedal gets more mushy as your pad wears down. You have more fluid in your caliper to make up for the thinning pads. For the longest time I couldn't figure out why. I kept bleeding with no luck. Then I changed pads and the problem went away.
It does, try again. http://www.joe250.com/cars/evo8/brak...ebleeding.html
What name brand of slotted rotors are you using?
I went with Rotorpros Drilled/Slotted Rotors, and Hawk HPS pads, and tenique (spelling?) lines..
Once I get the fluid bleed correctly tonight, the brakes should be feeling really good.
Front RotorPro = 20lbs
Rear RotorPro = 17lbs
Front Stock Brembo Rotor = 19lbs
I didnt weight the rear.
thanks!
