Suspension help?
Old Apr 18, 2009 | 01:46 PM
SleepySamurai13's Avatar
Suspension help?
I have Tein S. tech springs and perrin swaybar and mounts with whiteline endlinks and want to install some aftermarket adjustable struts, which ones are good and where can i get them? I also run in the local SCCA events and would like to know what might be a decent street track alignment with dedicated track semi slicks. any advice is greatly appreciated. thank you
Old Apr 18, 2009 | 04:07 PM
Smike's Avatar
Few things...
1. The only aftermarket struts that are adjustable for the Evo are the Ohlins fixed perch struts ($$$). Your options are Bilstein MR's (used) or Bilstein HD's (new).
2. Get a better set of springs. With sticky street or r-comps there is no way those soft springs will handle. And those limit your strut travel. I would recommend there the Swift Spec R's, GTWorx, or RobiSpecs.
3. You only have 2 camber choices up front (unless you have camber plates). Using the -2 bolt selection you should see between -1.5 and -2.5 up front. In the rear, I run -1.4. Zero toe and zero thrust angle.
Old Apr 18, 2009 | 04:34 PM
Jp7's Avatar
Jp7
just get the megan coilovers. Cheap and effective.
Old Apr 20, 2009 | 05:17 PM
thank you SmikeEvo, ill definently look into that. wheres a good place to purchase those from?
Old Apr 20, 2009 | 05:34 PM
Smike's Avatar
Contact Andrew at GTWorx.com -- he can get you squared away!
Old Apr 25, 2009 | 10:35 PM
Ive been lookin at the megan coilovers, and for the price, i like what i see. any opinions on those coilovers anyone?
