Alignment Settings/GTWorx/MR Bilstein
I just installed GTWorx springs (which feel great) and I am going to go get an alignment.
Upon some searching it seems like in general a good DD/street setup is the -1.0 setting with bolts up front and -1.0 on the rear. Toe 0.0 all around.
To those running this setup...what do you like to run for street conditions?
when i had these installed on my car kyb shocks though, i was running -2.1 using the camber position bolt, and -1.8 in the rear with 0 toe and it was great for dd and the occasional o sh*t ! driving, lol.
either setting for the front bolt is okay....just depends how worried you are about wear. IMO the -2 isn't bad but if you want to maximize tire life do the -1 setting.
- Andrew
- Andrew
