good ol' simple 17x8
Old May 12, 2009 | 08:09 AM
Edi-no-son's Avatar
Hey need a bit of advice...
Got a 2nd set of rims for minor trackwork, and its 17x8 +30.
Want a set of semis on them of course, but wondering what size should I be looking at and the benefits of each?
Stock size is 235/45/17 for evo9 standard rims, so I was thinking I'll get the semis in that size.
But from the limited knowledge I know, wider = more grip, but less acceleration.
and narrow = opposite.
But what about the middle number? What if i go 235/40/17 or something?
How would that affect the handling or whatever else it affects? lolz
Old May 12, 2009 | 08:26 AM
sscottttt's Avatar
A 235/40/17 tire will be shorter, I've seen people run this setup without any problems. It will give you a slightly smaller sidewall which can be beneficial in reducing sidewall flex, you'll also have a shorter gear ratio which can help or hurt depending on the track that you're running on. If there's a long straight then you may run out of gear before the end, however if there is no risk of this happening then the shorter gearing will help you accelerate out of the turns faster. IMO you should go with a 245/40 it'll be a little wider and a little shorter than stock size but not as short as the 235/40. Some will argue that a wider tire that bulges on the narrower rim will cause unwanted flex but I think the benefit of having the extra rubber in the ground will help even more.
Old May 12, 2009 | 08:28 AM
Smike's Avatar
track - 255/40/17
Old May 12, 2009 | 11:57 AM
Neal@tirerack's Avatar
Many have used 245/40-17 with no fit issues as well. 255's really like an 8.5" wheel.
Old May 13, 2009 | 04:42 AM
Edi-no-son's Avatar
245/40/17?
Sounds like the way to go with 2 votes lolz
255 does sound like its a bit too crazy considering semis are already 'fatter' compared to normal tires.
As for running outta gears, that's not a problem with the tracks here in Australia (at least not something I've run into yet with my slow-evo lolz
I guess i'll see it all depends on pricing.... I'll go with a cheaper option as I'm not pro, and i'm most likely not going to feel 'massive' amounts of differences.
But a 235/45 or 245/45 would be still 'ok' right, or is that a big no?? (i'm jus thinking of the choices i'll be left to choose when I get prices)
The main problem down here in Australia is not too many people buy semis, so rare sizes are ALOT more expensive than common ones, but if the '40' has huge significant difference, that'll become a big factor lolz
Old May 13, 2009 | 05:31 AM
There won't be a night/day difference between a 235 and 245. Only 1/4" wider on each side with the 245's. If the larger sizes cost a lot more I'd just stick with 235's.
Old May 13, 2009 | 05:39 AM
jve153's Avatar
i just picked up a set of dunlop star specs, the 235/45's and 245/45's were the same price (factory 17x8's). the 245/40's were considerably more so i went with the 245/45's, i have the tein s-tech springs on my car, and they rub just a bit, rolled my fenders, gonna have to cut the fender wells a little bit, but they are amazing.
Old May 13, 2009 | 05:45 AM
evremonde's Avatar
I would get some tougher springs before rolling+cutting fenders.
Old May 13, 2009 | 05:46 AM
Edi-no-son's Avatar
I guess i'll just stick with the cheapest option, unless the 40 ones are like $1 more expensive or something rediculous like that haha
Old Jun 1, 2009 | 08:27 PM
jaytypes's Avatar
245/40
Old Jun 1, 2009 | 08:56 PM
Evo_Someday's Avatar
It's my opinion that a 45 sidewall is too tall and gives too much flex. I'd recommend a 40 side wall and the widest tread you can fit and or afford.
Old Jun 2, 2009 | 01:51 AM
Edi-no-son's Avatar
Alrighty gonna give the 40 a try if I can find some!
The stupid thing is the market here in Australia is tiny, so you can only get the more popular sizes which seems to be the 45 >< ><
GregM
Sep 5, 2016 11:52 PM
CrazedRacing
For Sale - Wheels / Tires
11
Jan 30, 2011 11:03 PM
jshek
Mar 23, 2010 11:20 AM
YNGEVO
Aug 17, 2008 09:28 AM
ammitsuevo
Sep 30, 2004 05:35 PM
