Alignment settings article got me to thinking
Old May 27, 2009 | 07:58 PM
Kracka's Avatar
I was reading this:
http://www.ozebiz.com.au/racetech/theory/align.html
Which got me to thinking more about my alignment settings:
This was performed with me sitting in the driver's seat. I understand my slight toe-out in the rear helps the car rotate better in the tight auto-x situations, but my front toe being uneven concerns me a bit so I might get that looked at. Also, I'm wondering if caster is adjustable as I would like to run a bit more to help the car track straighter and increase steering weight. Thoughts/opinions?
Old May 28, 2009 | 04:17 AM
Smike's Avatar
You wound need to add camber plates up front and rotate how they are orientated so you can play with caster.
https://www.evolutionm.net/forums/ev...vs-caster.html
