Spacer questions
Old Jun 12, 2009 | 02:31 PM
SFO EVO's Avatar
Spacer questions
I did a search on spacers and came up with plenty of answers, I couldnt find one that tells me if i can run an 8mm spacer safely without moving on to extended bolts? Would it be safe,how many turns would i get and how many turns are required to define "safe"?
Old Jun 12, 2009 | 04:18 PM
goforwand's Avatar
I run 10mm spacers on the front of my track car and I wouldn't dare dream of not having APR extended studs.
Old Jun 13, 2009 | 05:27 PM
hendogg8's Avatar
I forgot home many "turns" are safe, but usually 5mm is the most you want to run with stock studs.
Old Jun 14, 2009 | 01:05 AM
SFO EVO's Avatar
thanks i was about to order some 8mm
Old Jun 14, 2009 | 09:32 AM
KnightRyderx2's Avatar
It should be 6-8 turns is the minimum recommended amount of turns for a 5x114.3.
Old Jun 14, 2009 | 09:56 AM
Evotech8's Avatar
^+1. Get extended studs. Cheap insurance for safety sakes.
I ran 5mm spacers before on stock studs and only got 4 turns max.
