Rotor question...
Old Jun 14, 2009 | 02:46 PM
Raceghost's Avatar
Rotor question...
When I had my upgraded rotors put on my car, the fronts were put on directionally straight, but my rears are in reverse. Can I just swap them around, pull the driver, put on passenger, and visa versa? Also, is it a pain?
Ryan
Old Jun 15, 2009 | 06:14 AM
Smike's Avatar
I would put them to however the manufacture calls for. Its not a pain. You will have to unbolt the caliper, which is easy to do. Make sure to re-torque everything to spec when finished.
Old Jun 16, 2009 | 01:38 AM
1sxyrxy's Avatar
you can just flip them if you installed them wrong, like you said, just switch the passanger with the driver side. its not very hard . should take about an hour.
Old Jun 16, 2009 | 01:42 AM
LancerEVA06's Avatar
And an hour is at the very slow end. Should take about 10 minutes or so a side.
Old Jun 16, 2009 | 07:03 AM
ncaruso23's Avatar
Its a quick easy fix. No worries.
Old Jun 17, 2009 | 08:17 PM
1sxyrxy's Avatar
i factored in if hes never done it before
