quick question:)
Maybe this will help get a response these wheels are gorgeous!!!
http://www.ti-wheels.com/ti5/ti5.html
I know pattern wise it will, I was refering to offset for caliper clearance purposes...I was hoping someone had pulled the trigger on these they're beautiful esp the white with neochrome lip.
I don't see any offsets of sizes there that look like they would fit without needing either a spacer to clear the front brakes or fender rolling and depending on the shape of the spoke (which is almost impossible to tell from a picture) even a low offset wheel may not clear. I would say the sizes that will probably come closest to fitting if you don't mind doing a little work would be: 18x8.5 +40 (with front spacer), 18x9.5 +30 (rear fender rolling req'd), or 18x9.5 +40 (front spacer and/or rear rolling maybe necessary)
