d2 coilovers, chasis brace
i was browsing online and i saw d2 makes a 36 way adjustable coilover kit for the 06 evo anyone have experience with these ???
also the factory tie bar on my evo the one closest to the cat got bent the other day and i bought a GTSpec ladder brace to replace the OEM tie bars, however one of the holes isnt lining up correctly because the factory tie bar closest to the cat got bent. my question is would be ok if i hit the bracket in more to make it align better ?? its only off by like under a half inch
d2 - cheap. Expect performance to be in line with that.
What will you be using the car for? I would put a lot of research into your suspension.
the 36 way adjustable thing doesn't mean anything....36 clicks of adjustment doesn't mean anything if all 36 suck. often times the adjustments don't actually do anything or are completely inconsistent.
step back and think about what Smike said....what's going to important is figuring out what you need for YOUR uses.
- Andrew
- Andrew
i want good handling i like to dip on the highway and i also like runnin it in a 1/4 mile im new to awd turbo so thats why im a little unexperienced wit these things but as far as i know the d2 coilovers for the hodna game were pretty good >>> what do u guys suggest i do ??
where can i find the swift/ mr bilsteins setup, because i had tein dropped springs on my evo but the guy used the stock strut and it threw the caster on the passenger side way off, this is my first awd car so any other suggestions will be great !!! and also i dont have the 6 point chasis brace i have the GtSpec 4 point Brace that goes into where the stock tie bars go got them off jsc speed. COuld i do the same thing though ??
I got my bilsteins from tirerack...but if you can't find a set try and get some of the mr bilsteins that are blown for cheap you could go ahead and get them revalved from bilstein for 75 bucks a piece
Ive never had an issue with a set of D2's yet.. They work very well for the price when setup with the right springs...
https://www.evolutionm.net/forums/ev...ml#post7131546
