brakes
Old Oct 15, 2003 | 01:26 PM
mphevo's Avatar
Question brakes
evo VIII, my brakes have been squeeking/vibrating since the 3rd day i've had the car... i asked the service manager at the dealer about this he said putting more grease between the shim and the pad will correct and that's the course of action he took... he said it's a common problem with the car... anybody else have this problem?
Old Oct 15, 2003 | 11:33 PM
evoD's Avatar
the evo comes stock with brembo calipers....and pads. semi- and full race brake pad compounds usually are noisier....and yes that annoying squeal at lower speeds is a characteristic of it. at worse...jus tell people ur car's complaining that its going too slow....
Old Oct 16, 2003 | 05:24 AM
mayhem's Avatar
Yeah, don't worry about it. Unless you mean something else by using 'vibration' other than making noise.
Old Oct 16, 2003 | 10:34 AM
Dale_K's Avatar
You will find several other threads on this subject with the search function. Some reference a Technical Service Bulletin from Mitsubishi.
