Grid F issueitment
Old Sep 20, 2009 | 02:57 PM
insanechief's Avatar
Grid F issueitment
Ok i need a lil help. I am planning to get the Rota Grids with 18x9.5+20mm offset. Thinking about a 235/40 18. I really dont want to roll my fenders due to it will cost more inless i DYI. Do you think i will need them rolled?
I am lowered 1 inch in back with Tanabe springs.
Please help cuz i dont want to get them being all pumped up and then not fitting.
Thanks
Old Sep 20, 2009 | 03:15 PM
8UpUrV8's Avatar
A guy that runs them on his IX said he had to roll the inner lip of the rear quarters so it wouldn't rub, and had to grind a small part of one of the calipers
If it's as simple as rolling beating in the inner lip it shouldn't be too much of an issue
Old Sep 20, 2009 | 03:17 PM
What grind on the caliper???? Theres no way i would do that.
Old Sep 20, 2009 | 04:09 PM
8UpUrV8's Avatar
Then you'll need to run a spacer or choose a different wheel.
Old Sep 25, 2009 | 02:57 PM
ok anyone else because i have not heard about running a spacer.
Old Sep 26, 2009 | 03:43 PM
Anyone Who has the Grids on an EVO VIII please speak up.
Old Sep 26, 2009 | 03:49 PM
8UpUrV8's Avatar
Mine will be here on Friday, i'll let you know.
FYI- Grid's have about 1mm caliper clearance in the front so if the rub- you'll need to grind that small part (very small i'm sure, don't be a wuss) or run a 3mm spacer.
You WILL need to roll the rear inner lip. If you're not willing to do so... like I said find another wheel.
Old Sep 26, 2009 | 05:04 PM
igo4bmx's Avatar
u can run a 5 mm spacer up front and hammer the rear fenders for free
search here someone did it
Old Sep 26, 2009 | 06:08 PM
josel_atr's Avatar
will you have the same rubbing issue if you choose a different size of tires?
Old Sep 26, 2009 | 06:43 PM
Oh as before I love those rims but not wanting to shave on my calipers. So I guesss the spacer here i come. So i would love to hear from my EVO VIII and IX peeps who have these. i know they fit perfect on EVO X.
Old Oct 7, 2009 | 05:31 PM
8UpUrV8's Avatar
I installed my Grid's the other day, they clear the front calipers by about 1mm,
I grinded that area down to get about 2mm of clearance, then repainted all the calipers.
You can't even tell they were grinded.
Rear Quarters need to be rolled, even on stock suspension they rubbed in the rear over bumps.
Fronts cleared stock suspension perfect, no rubbing at all even lock to lock.
Fender liners were ziptied from the last wheels/tires I had, so I left them like that.
If you're scared to do such little grinding just get 3mm spacers for the front, however you're calipers probably need to be repainted anyways
Lastly- you def need coilovers to make the car look perfect, I don't think drop springs will lower the car enough to cover these wide azz wheels.
Old Oct 7, 2009 | 05:39 PM
evoix16's Avatar
Got them on my IX no fitment issues in the front didnt grind anything and as for the rear I have greddy coilovers and it bearly rubbed on the very very outside with a 255 35 18 so I had the inside rolled with a true fender roller for 50 bucks
Old Oct 8, 2009 | 05:31 PM
Im still curiouse why do some people have to shave there calipers and some dont even with the same off set?
Old Oct 8, 2009 | 05:37 PM
8UpUrV8's Avatar
You don't HAVE to shave the caliper. But being so close, I did it for piece of mind.
Old Oct 8, 2009 | 05:45 PM
Would it be better for maybe a 3mm spacer then to shave metal off the calipar?
