Tire Question
Old Oct 4, 2009 | 09:31 PM
Reminiscence's Avatar
Tire Question
I've been reading around and searching, a lot of info, and I just wanted to make everything clear. I'm interested in getting Volk Racing-CE-28N 18x8.5 with a 5x114.3 bolt pattern and 25, 30, 40, 47, or 52mm offset. I'm running stock now and new to the tire scene, which tires/tire size/offset would work?
I've read that 255 35 is the ideal size for 18s, I'm just concerned about rubbing and clearance.
Old Oct 4, 2009 | 10:14 PM
chaotichoax's Avatar
255/35/18 and or 245/40/18 are your best bets
rubbing depends on suspension set up and brand of tire
wheel offset your best bet would be +30
Old Oct 5, 2009 | 12:32 PM
Neal@tirerack's Avatar
+1 255/35-18. Prob the most common fit and majority of what 18" guys are using.
Old Oct 5, 2009 | 09:04 PM
dambikeracer's Avatar
Originally Posted by chaotichoax
245/40/18 is your best bet with an 8.5" wide rim
For the wheel offset, your best bet would be +30
+1 There will be no rubbing! They will fit perfect!
Old Oct 5, 2009 | 09:13 PM
NSS's Avatar
NSS
+30 for sure
Old Oct 8, 2009 | 06:04 PM
Ah ok, thanks a lot guys!
Old Nov 3, 2009 | 05:29 PM
Calling upon the knowledge of EvoM! I've been thinking about this new setup:
Either:
Advan RS 18x8.5 +31
or
Advan RS
18x9.0 +29
both with 245/35/18. No clearance/rubbing issues?
