Stiffness question
Old Oct 7, 2009 | 05:13 PM
toverton30's Avatar
Stiffness question
I have Nex Coilover and the front is stiffer than stock.. thats ok but tjhe back is really soft. My question is if i get higher spring rates willl that make it stiffen up? ( i do not kno wwhat spring rates are on there) it has maxspeed spring it says 180060 07/06 something like that on the spring.
Old Oct 8, 2009 | 04:50 AM
Smike's Avatar
You need to know the spring rates. Thats one of the first things to know when buying any suspension part.
Old Oct 8, 2009 | 05:48 AM
MrBonus's Avatar
Without spring rates, you're only asking for conjecture. Most likely, your rear spring rates are lower than your fronts which is generally incorrect for Evos.
