clunking in front end
Old Oct 19, 2009 | 02:55 PM
electricman's Avatar
ok so i just replaced my struts, new tie rods, tein lowering springs lower control arms and i still am getting a noise in my front end i havent got a allignment yet but iam not sure if that could be my problem anybody else dealt with this
Old Oct 19, 2009 | 04:59 PM
inco9nito99's Avatar
When does it happen? Over bumps or just when you crank the wheel left/right?
Old Oct 19, 2009 | 06:33 PM
clunk
im hearing it in low speeds first and second gear 5-25mp going in a straight line or turning. just little bumps in the road or in my gravel driveway makes the noise
Old Oct 19, 2009 | 06:49 PM
Kracka's Avatar
Is the top center strut rod nut tight?
Old Oct 19, 2009 | 08:02 PM
tsidrift1's Avatar
Hey electricman, you Chris' buddy right? I talked to you at owners day. Anyways, my evo has been doing the same thing. Mine clunks as I am pulling out of my drive(on a hill). Then as I start in first it pops again.
It seems like something is shifting out of place and then shifts back into place when I begin to roll forward.
There is a huge thread on here about the clunking in the front end.
Old Oct 19, 2009 | 09:58 PM
Evo-Mike-2's Avatar
Is it a clunk or a poppin ? Dose it do it more when your turning? And did you replace your strut mount? On the 8s and 9s they have a big problem with the strut mounts.
Old Oct 20, 2009 | 05:07 PM
hey
yeah iam chris friend i will have to check that out. so did you figure out your problem
Old Oct 20, 2009 | 05:08 PM
nut
yeah i checked that it is tight
Old Oct 20, 2009 | 05:12 PM
struts
it sounds more like a clunking noise, it does it more going straight i would say. my struts and top mounts where off a eight with 10,000 miles
Old Oct 20, 2009 | 05:43 PM
tsidrift1's Avatar
I havnt figured mine out yet. I am gonna take a look at it real soon though. The car will be going into the garage for the 60k maintenance soon, ill look at it then.
Old Oct 20, 2009 | 06:39 PM
dastallion951's Avatar
well easy way to check found a similar problem with mine found when i popped the top hat cover for the drivers side front strut, grease all leaked= busted mount....n im only at 60k on the 03 chassis....
Old Oct 20, 2009 | 06:40 PM
another thing to check to see is if u put seated the spring right on the strut...could cause a noise...
gl
Old Oct 20, 2009 | 07:04 PM
struts
i will get it on a lift this weekend to look it over
Old Oct 21, 2009 | 02:09 AM
diskombob88's Avatar
i have a evo x gsr and i just lowered it with the eibach pro kit and my front right side does the same thing from 0-25 mph it clunks it feels like its the spring im going to reseat it in the morning ill post the results
Old Oct 21, 2009 | 10:17 PM
NSS's Avatar
NSS
dang.. good luck seems like a common problem
