Wheel Alignment advice for track day
Hi guys
firstly, i've got an JDM evo 8 MR, with a whiteline adjustable rear swaybar and tein super street coilovers. i'll still be using street tyres.
I'm going to my first track (circuit) event in a few weeks and im trying to sort out what sort of alignment settings i should be using. Im only new to awd cars so im not quite sure how and what they will respond to best. i'll still be using street tyres.
at this stage im not too worried about tyre wear on a daily basis cause im going to be getting my alignment set more conservatively after the track day.
So what settings would people suggest?
i was thinking something along these lines
front camber -2 degrees
front toe IN total 1mm
rear camber -2.5 degrees
rear toe IN 1mm total
i don't have castor adjustment so thats not possible.
Just zero out the toe... Any minimal advantages are usually outweighted by increased tire wear.
Get rid of the toe, it'll absolutely destroy your tires and in any case toe OUT would be preferred.
Robi recommended -2.8 front, -1.4 rear, and zero toe to me.
0 on toe front and rear, and what was posted on the fronts is perfect 2-2.5 and 1.5 rear..if you have ability more positive caster. but I don't think you have what is needed for that.
goofygrin
88
Jul 24, 2022 08:22 PM
Jonno99
May 3, 2017 08:02 PM
SmokingTires
Jan 12, 2011 01:55 PM
Blacksheepdj
Lancer Troubleshooting
114
Dec 7, 2008 09:14 PM
andber
May 28, 2007 10:16 PM
